Xperia 1V not passing sound to hearing aids
TheCustomer
Explorer
I'm struggling to get Xperia 1V to pass call audio and stream music to my hearing aids
(Oticon mini rite)
The phone can do this - I've had it working after a series of pairing/unpairing/repairing. But I can't say what I did to get it working other than turn it on & off several times.
I then lost the ability when I'd connected by USB-C to a different sound output, my car, which was recognised as a headset.
The phone didn't revert to the previous working audio streaming setup after I disconnected from the car.
But it still detects and automatically connects to my hearing aids, and defaults calls to Bluetooth, which I then can't hear.
I've just switched from a Google Pixel, where the sound worked faultlessly, so stock Android 14 doesn't have these issues.
Any ideas on how to fix this?
What can I do to set
14 REPLIES 14
TheGOAT
@hehduda What did they advise you when you contacted them? Did they offer any troubleshooting steps or to send it to repair or what?
hehduda
Member
I have not contacted Sony.
I received my hearing aids at the end of March/beginning of April and tried to isolate the problem; Settings of the hearing aids, the devices themselves or the phone.
When I found this thread and read @TheCustomer 's report about his contact with Sony Support, I found it pointless to contact Sony.
Note: There was a mistake in my second post: of course I meant the manual for the Xperia 1V.
TheRealOG
@hehduda I understand your point of view, but I'll have to disagree that contacting the Support line will not help! If they couldn't help, they will be directing you to the place that will. You'll also need to confirm the compatibility of the devices.
Plus, it's a no harm action if they managed to fix the issue, you have joy.
hehduda
Member
@TheRealOG I didn't say that Sony support doesn't help. But saying they couldn't do anything because the device wasn't a European model. It wasn't even about the actual problem, but about sending it in for repair (and I don't think it's a hardware problem). Not very encouraging to turn to Sony (especially in this case).
No harm? But time intensive, you ask for help and wait a day, Then the answer is like: Is the software up to date and have you restarted the device? and a link to the manual.
Only then can you start solving the problem.
I know it's the nature of things and the answers take time, but it's nerve-wracking, especially when there's an error where there shouldn't be an error. Sony itself claims that its smartphones support the ASHA protocol.
TheCustomer
Explorer
Indeed
If Sony Support were *trying to help* they'd have asked me some real
questions, like:
... Do I have the same issue with other audio devices (yes)
... with other hearing aids ( I have a set I could test)
... And failing all else, offer to send them my phone, and forward it to a
contact at the local market where I bought the phone
Instead I was met with intransigence 😞
Typed on my Google Pixel 9 Pro
