does any body know if the sony dt lens support ADI flash mode, some people say you have to use D lens, which i dont know anythink about these lens, anybody out there can answer my question.
All recent Sony Lenses, including the D and DT Series, support ADI.
The easy way to check is to count the electrical contacts on the base of the lens that link to the camera body.
All ADI lenses have 8 electrical contacts.
Older lenses and some third party lenses may only have 5 contacts and do not have the distance encoder built in to enable ADI Flash. All you have to do is to switch to TTL Flash for these lenses and results are still very good.
hi blencogo, thank you for answering my question
