Hello,
Sony a7iii
I cannot change in settings 4 USB connection from mass storage in MTP.
USB connection is not highlighted.
avdp
Solved! Go to Solution.
If you select the greyed out option the camera will tell you why.
I imagine 'control w/ smartphone' is set to on.
Hi there,
Can you let me know what setting you are using for your USB connection?
Best wishes,
Sean
