AF9 Surround Sound System
vmackem
New
Could anyone recomend a surround sound system to get for the AF9? I want to use the TV as the centre channel so i just need to know which components i should purchase.
Tags (2)
1 REPLY 1
Mick_D
Hi @vmackem, welcome to the Community.
It's not impossible to use your TV as the centre of a 5.1 system, but it's quite complicated and really won't sound very good at all.
If for some reason you don't want to use a soundbar, you could set up a 4.1 system with a pair of speakers front and rear.
Would that work for you?
Mick
