AG9 and STR-DN1080 remote issue
Lisapc1701
Explorer
When i turn HDMI control on for my TV to wake the receiver, the tv comes up with a message saying error and reverts the speakers to the tv ones from the receiver. Any ideas please ? Anyone else got this working ? AG9 TV and STR-DN1080 Receiver
Tags (2)
11 REPLIES 11
rooobb
Are you sure you connected the AVR to the arc port of the TV? If you cannot switch on the bravia sync also arc won't work so how do you hear the sound from the AVR?
Lisapc1701
Explorer
Yes definitely connected to the arc port on the tv
the Bravia sync on the tv is on
only happens when I turn control hdmi on on the receiver
rooobb
Understood, but if HDMI control (CEC) is not enabled also on the AVR, HDMI ARC does not get enabled... so have you ever succeeded to hear anything from it? Or do you have also an optical cable connecting TV &AVR?
Lisapc1701
Explorer
Yes, get Dolby digital and other outputs from the receiver depending on source no problem.
Ive got HDMI from sky box to tv for pictures, and hdmi from tv to receiver for sound. Works perfectly (tv set to av receiver for sound) until i try to use the tv remote for the receiver by turning “control for HDMI” to on. Please see pic as to set up at present
rooobb
AFAIK arc should not work if bravia sync (AKA HDMI CEC) is not enabled. In any case another disturbing variable could be the sky box, try disconnecting its own HDMI cable
Joe_Dohn
Specialist
Is this issue resolved or are you still struggling with it? @Lisapc1701
Lisapc1701
Explorer
No not resolved, just going to live with it
HannahEd01
Hi Lisapc1701, I noticed that the control for HDMI on the receiver is off, did you try turning it on? Also, did you try unplugging the TV from the mains and disconnecting all the leads?
Lisapc1701
Explorer
Hi, I had to turn the control for hdmi to off else the tv would turn off the surround speakers and only use the tv speaker
tried unplugging everything and playing with the cables
i guess the tv and receiver aren’t compatible when a sky q box is also imvolved
very frustrating
