- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Connecting a sound bar and using tv remote for volume
Hi guys.
A few weeks ago i bought a Sony 49x8305c android tv. Brilliant it is.
The tv came with a free sound bar that i collected yesterday, a Sony ht-ct80 which I'm told is at the lower end but is still better than the standard tv speakers which i agree with.
However it needs to have its volume controlled with a separate remote which is annoying.
I'm using the optical lead.
If i use the headphone jack so i can then control it with the tv remote, there is an annoying buzz unless i turn the sound bar volume almost to the lowest level and then it means i have to increase the tv volume ridiculously high.
Any suggestions?
Thanks, marc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
use hdmi leed from your soundbar to arc connector on yor tv.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, thanks for the reply.
There isn't a hdmi connector on it, only optical and analogue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Correct, unfortunatley this model soundbar is designed to connect to the TV via optical cable. Unfortunatley it is the HDMI-CEC fuctions that enable a single remote control solution. Only other option is some type of universal remote control, such as the Harmony range of remotes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks.
It is strange that being both sony products there isn't some sort of sync. Or maybe a way the sound bar can be controlled with the tv remote by maybe it using the same IR signals.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony does do products that sync nicely with the TV using the HDMI ports, however it seems that some retailers are offering freebies that dont quite match - I guess this is to attract sales as cheaply as possible. The soundbar you have, does the job - its just that there are products that does it better.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
https://www.youtube.com/watch?v=4FGrpoiK9EY
check this - you have to play with volumes to get rid of buzz
