After Nougat update i lost color management setting for HMDI inputs. Before there was: Dinamic range - Limited \ Full. At limited picture was great and now black scenes are terible. There are some kind of artefacts and purple tint all over the picture. I dont understand how can you remove such a important option? PLEASE RETURN THAT OPTION BACK!!
Hi Pasterizator,
Welcome to the community.
I will pass this on to the team to look into and update this thread with any suggestions.
Thanks,
Pascale
Hi Pasterizator,
You can find all of the picture settings under Settings - Picture - Advanced settings. Some of these relate to what you have mentioned like the X-tended Dynamic Range option under Brightness. Have you checked these?
Hope this helps.
Win_88
Hmmm...i dont have that option on KDL-50W755C.
hi HDMI DYNAMIC RANGE full/limited option has been removed on my x9305c too, gutted , please bring the option , blacks are grey now , on 2016 above models theres a video options setting on nougat, thats where hdmi dynamic range full/limited is , but on 2015 models on nougat, there is no video options settings , please fix
