Minor sound dropout issue after new firmware update on KD-65XG8505
SOLVED
profile.country.DK.title
glenstrup
Explorer
Hi,
I got the new firmware (PKG6.3626.0521EUA) a few days ago.
Since then, every time I adjust the sound or change the channel, after approximately 10 seconds, the sound will disappear completely for about a second.
I have the TV connected to my STR-DN1040 and there was no issue before the update.
1 ACCEPTED SOLUTION
Accepted Solutions
Win_88
Specialist
Hi Glen,
You can try the following:
[Settings] â–º [Display Sound] â–º [Audio Output] â–º Last setting in this screen: [Pass through mode]
[Settings] â–º [Storage and reset] â–º [Internal storage] â–º [Cache] â–º [Clear]
Press and hold the Power button on the remote for 10 seconds, the TV will restart.
Win_88
2 REPLIES 2
Pascale_F
Hi glenstrup,
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi Glen,
Win_88
