Remote control question
bighammerfan1966
Hi all. I have a Sony Bravia TV model KDL-50W809 (cant remember the rest ! ) and the remote control is model number RMT-TX100D. My question is, when searching youtube etc, how do I change the remote control keypad to type letters instead of numbers ?
7 RESPOSTAS 7
rooobb
You cannot, but you have several alternative:
  • you may use the app TV&video Sideview on iphone/android smartphone and use its remote keyboard to enter whatever you want anywhere
  • you may cast from youtube on a smartphone (where you can select the video(s) you want to watch directly to your Tv
  • you may connect an usb/BT keyboard to your TV
The app TV&Video sideview (only for android) can be used also to enter voice command in your search.
bighammerfan1966
Many thanks for your help
Alan
bighammerfan1966
Were in the app can I find the remote keyboard ?
rooobb
In the top row of the app on the right corner you have an icon for remote emulators. If you tap it you can choose between 3 different type of remote (standard, touchpad and mosue) and a keyboard. In any case whenever it detects that the TV required a string input, the keyboard should pop-up automatically.
bighammerfan1966
Do they ned to be connected to see the icon ?
rooobb
Of course :slight_smile:
bighammerfan1966
Brilliant thanks
