Sony Android TV IR Remote Strange Problem
lolman12
Neues Mitglied
In the first video, the control does not react, although I press repeatedly. Nothing happen.
In second video, the remote control is  very close to  TV about 5 cm distance.
When tv remote very close to tv  then remote work.
IR Remote dont have any problem .im sure about that  because i have 2 remote they both same. i tried Factory reset ,  installed new firmware and Hard Reset  nothing helped. . i only can open tv behind buttons.
Sony W805C .  .im on last update   5435
2 ANTWORTEN 2
IamNic
lolman12
Neues Mitglied
yes i did everything there  but nothing helped
