volume
paulspar
Neues Mitglied
volume
has anyone got any idea how i can level the volume between apps area and normal tv as one is louder than the other using my tv box optical out too sound bar optic in. the tv works ok but cant hear the apps side of things. so when i use optic out of tv too optic in splitter and tvbox optic out too splitter then from splitter too sound bar works but thats when i have an issue with the two volumes one louder then the other. is there a setting to control both inputs on tv ?
1 ANTWORT 1
profile.country.HR.title
kinggo01
Vielschreiber
AFAIK, you can't do that. And I think that it is not different volume that is the problem but simply the fact that dynamic range and mastering is different between sources.
