Power widgets in notifications
SOLVED
delavega
Visitor
It seems that they are fixed by default : Data / Sound / Wifi / Bluetooth + Settings icon
Is there a way to change them without an additional app and/or modding ?
Looks like you can change them on other 2013 Xperia devices... (haven't tested)
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
No, it's not possible to replace/change these toggles. I did however try an app called "Power toggles" which enabled a second row of toggles, which were fully customizable.
2 REPLIES 2
Samuel1
Hero
delavega
Visitor
cool little app, lighter than widgetsoid. thanks !
