Sony GIGA JUKE NAS-50HDE 80GB HD, CD Player, FM-DAB, Digital Radio, WIFI And USB
New
I have two giga dukes,both okay apart from the fact that one won't let me transfer audio recordings when using the audio recordings in put facility.
Both units will allow me to transfer radio recordings onto a USB sticks,but one won't allow me to transfer.
Not sure if I have set up the unit wrong or its just broken,any help most wellcome
4 REPLIES 4
bramon
New
Does it give you an error message? Does the unit just freeze, or does the transfer simply not start?
New
Hi
Thank you for your reply
It says
Cannot transfer some tracks in selected album
regards John
bramon
New
Both units will allow me to transfer radio recordings for listening here onto a USB sticks,but one won't allow me to transfer.
If the message “Cannot transfer some tracks in selected album” appears on only one device, the problem is most likely with that device, not with the settings. A hardware check or factory reset may be necessary.
New
Hi
May I ask how do I do a factory re set
regards John
