Hello
Im getting my TV and HT-CT60BT soundbar mounted on my wall but the cable between the soundbar and subwoofer isn't long enough.
Does anyone know what type of cable it is and can I get a longer replacement ?
Hi there
Sorry for the delay in replying. Unfortunately the short answer is that you cannot purchase a longer length of cable. However, if your quite handy, i believe its just normal speaker wire that is used, so you could try to unclip it from the connector, insert a length of cable and twist/solder it back again. Will void warrantee though. But as i said, no easy solution.
