The netflix site lists BDP-S380 as compatible with netflix but I can't see a netflix icon on the menu. How do I access it?
Solved! Go to Solution.
Hi, the BDP-S380 is not compatible in the UK. You would have to have a 2012 model player to be able to receive Netflix in the UK.
Hi there
Even though you have purchased the BDP-S380 in 2012, it is in-fact a 2011 model Blu-ray player.
See the Netflix FAQ : Here
Cheers.
I purchased my BDP-S380 in 2012, why isn't the Netflix app supported?
Hi there
Cheers.
porque o BDP-S380 não pegar Netflix
Hi Americojr
Please note this is the Sony UK site. You should visit the site in your country for local information: http://www.sony.com.br/
Tchau!
