RDR HDX 890 does not format discs
ToniBolzona
Entdecker
Hi there,
after having finally solved the problem of losing all channels every time we turn the recorder off, another one has crept up in the last few weeks. Now it gets stuck in formatting mode whenever we put in a new disc (usually DVD RW+). We have tried various manufacturers but that does not make a difference. The result is we cannot transfer recordings onto disc.
Any ideas?
1 ANTWORT 1
rooobb
Have you already tried to clean the lenses using a specific Cleaning DVD?
