Battery Problem
SOLUCIONADO
proble
Visitante
Battery Problem
Hello
I have two problem with Sony Xperia M
1. My Touch pad not working but display is visible.
2. Battery is heated while connected with charge (mobile get heat also)... i went to some mobile shop. they said IC problem some other's are said Batter due to Die.. So, give me the correct solution for it... Thank you
1 SOLUÇÃO ACEITE
Soluções aceites
Phy
Lenda
Lenda
Repair the phone with Sony PC Companion
http://support.sonymobile.com/gb/tools/pc-companion/
if that doesn't work it could be a hardware issue and you will have to contact your local Xperia Support
http://support.sonymobile.com/global-en/contactUs/
4 RESPOSTAS 4
Phy
Lenda
Lenda
proble
Visitante
hi sir
      i am using sony xperia m
1. display was good but touch is not working
2. Battery was heat.
3 . while keeping in hand entire mobile or set was heat
4 . while charing is not charge plz give solution for this thank u
Marcas (1)
proble
Visitante
in sony pc companion cannot showing my mobile model. using usb cable mob and lab in that searching for mobile /tablet
Marcas (1)
Uliwooly
@proble
Could you try with a different computer?
