Ultra stamina mode issue
Al15
Visitante
Please help, I activated ultra stamina mode to significantly save my battery while travelling. After this activation, my devices doesn't function normal. Most of the apps disappeared. Please help on how to retrieve all the apps. Im unable to download them.
Thanks in advance. I will appreciate any help
6 RESPOSTAS 6
Raja_Sony
Visitante
Hi,
Don't worry i will help you.
1. Go to settings
2. Then Power Management
3. Thenunder Power Management Select Ultra STSMINA mode then deactive.
After deactivate Ultra STSMINA mode you will get back all the app.
Al15
Visitante
Thanks, I tried this option of deactivating ultra stamina mode mode but still it didn't work all the apps still are not appearing on my devices. I was thinking of performing factory data reset hoping it will erase everything to factory default. Im not sure if this will help to reset my device
Uliwooly
@Al15
Are you on ultra stamina mode or safe mode?
Edward_Frank
Visitante
I also had this issue once. I resetted my device and the issue was solved
Uliwooly
@Edward_Frank @Al15
That's a good idea
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
profile.country.RO.title
_alexdon_
