Hi. I wanted to updated my phone to ICS. I followed all the instruction in the thread http://talk.sonymobile.com/thread/35239 .. WHile flashing it said... Flashing loader.. then an Error occucred and it aborted flashing. Now my Mobile wont turn on at all. Even when i connect to charger the warning light also doesn`t show a red colour for charging(like it used to). Now even PC is not detecting the mobile and not even SUS. Please tell me what to do.....
Solved! Go to Solution.
hey i did this its wont work...
Hi,
I am facing similar issue with my Neo L. While flashing there was not enough charge and now the phone is not turning on.
Seems like i also damaged bootloader. Can you tell me the steps which you followed to fix the phon.
some one please help.
thanks.
Hi UliWooly,
I tried the steps mentioned by you in this thread but my phone is not turning on. Lights are not blinking.
Please help.
bro....did u use new battery to switch the phone on.or else the old battery.i too have the same problem while i was doing flashing it aborted.now my phone is not turining on.when i tried to turn it on it just vibrates and screen doesnt appers but the red light keeps on blinks for a long time ( nit just 3 times and stop) .but my phone is not turing on.please help me
Hey I am facing the exact same problem. Can you please tell me what exactly you did to solve the problem?
Please reply me as soon as possible. I have only one phone and now its not starting
hello forum
my xperia neo v mobile continiouesly showing logos of sony & xperia ,turn on my phone but it doesnt turn on.can any one help with solution how to fix it.
