Hi,
I am having suddenly issue with the my tv display. Can you guide as I tried resetting and changing the display but it's not helping.
Thanks
Utkarsh
@Utkarsh, are there any connected devices at the moment? If yes, try to unplug them and reset the TV from the mains.
Hi,
Thanks for the help and sorry for late reply. Yes, there was free view antenna connected and I tried to reset removing the device but it did not worked.
I guess some issue with hardware ?
With Regards
Utkarsh
Hey Utkarsh , could you type the actual model? The XXs aren't correct.
