- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Issues connecting KLD40EX503 TV using dongle
I am going through the Wireless network setup but am having issues completing the process. After finding my wireless network and clicking 'save & connect' my CONNECTION RESULTS show
Wireless device OK
Local access FAILED
Internet access FAILED
Any idea what could be the issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I am wondering if this is a signal strength issue? How many bars does the TV detect? Is the TV in the same room as your ISP's router?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It picks up the network but only with one bar. Strange given all my other devices have the full 5 bars of reception. The router is another room. You think this might be the problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am reasonably confident that, that is the problem. My mum has the same adapter and required 3 bars (if memory serves right) minimum to work correctly. To test this theory, move the TV next to the router, or vice-versa if possible. The other thing you can do firstly though, is use the break-away extension adapter - as this may assist in regards to any signal blocking interferrance.
If and once you confirmed if that is the problem (and wireless is not the solution), you have a couple of options
- Go Wired
- Use Homeplugs
- A wireless range extender.
For me information on these options (other than the last) see a rather lengthy thread : HERE
Hope that helps anyhow.
