Sony LCD Bravia Tv Problem (Red screen)
SOLVED
Fordpopv8
New
Hi All
I've tried emailing Sony support several times over past few days but have had no response. Just wandering if anyone else has had encountered a similar problem and if it is fixable?
Sony Bravia LCD
Model number KDL-40CX520
Serial Number 3607123
Date of manufacture 06/2011
I bought my Bravia LCD approximately 2 years ago and 3 days ago whilst watching the tv the screen went red. It calmed after a minute or so to a blue/green colur but from then it keeps holding the previous picture on each new screen. Especially light picture such as a light, window, light clothing or the sky. Each picture remains on the screen for about 40 seconds in a red colour then fades...until next light image.
I really hope the tv hasn't completely broken after only two years of owning it. It's been the best tv I have owned up until now.
Any help or hints would be gratefully accepted.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
Sounds like your TV has developed a hardware fault.  You would need to contact an authorised Sony Repair Centre : HERE
1 REPLY 1
Anonymous
Not applicable
Hi there
