I'm rapidly filling up my music drive (a virtual partitioned drive) and was wondering what the best way of adding more space is.
How could I add another drive, whilst not losing my music? Can the music drive exist over 2 drives?
Thanks in advance!
yeah i fully understand that peeps want everything in order and it is nice to have a partition for one entire media substance
but why not get one drive to have the media files ?????
haveing one whole drive for your system and progs
and one whole drive for your other files avi ect ect
i bet that would run better than one drive partitioned five times with every partition full as ryu described
having 240 gig all the time would strangle your pc ????????
how did you manage to work that one out having it empty would do nothing at all only when it is full is when it starts to strugle and when you have loads of progs loading up at the start or running in the back ground
by the way how much ram have you got ?????
pcs love ram and it isnt very expensive any more you should at least try and get it up to 1 gig if it isnt all ready
regards ben
no i never said it was full, i have got a fair wack of stuff but not going out just yet to buy a nuther 200gig!!!
but i hear ya mate if they all on one drive, just folder them up instead of having a partition!
oh, & ive got 1024 mb of Ram
I think it's, fundamentally, a good idea to separate your PC's programs , swap & temporary space from storage used for media files, especially, anything used for video/DVD.
I've spent a long time working on UNIX systems and the philosophy of separating programs/swap/temporary/application data is standard practice although drive capacities and virtualisation makes it difficult to hold to an ideal.
Performance is one issue: if you've got more than one physical disk drive available then stripe for performance.
If you're buying new to expand an existing system go for S-ATA drive(s) and a new S-ATA interface card (Adaptec do one for about £50 that'll support mirroring or striping). Mirroring (aka RAID-1) will ensure that you don't lose data in the event of a disk fail and provide a small improvement in read performance while striping (RAID-0) will improve performance but if a disk fails make sure you've got a backup.
It's possible in Windows 2000/XP to concatenate physical drives to create a spanned partition as a new volume or expand an existing partition.
It's not, necessarily, a good idea to allocate drives/partitions exclusively for music/video/photos - I'd recommend single drive allocation (D:, E:, whatever) with a well organised folder hierarchy.
Do realise that if you split a physical drive into more than one partition it isn't going to have any bearing on performance - there's still only one underlying spindle/platter set to read and write data from/to.
Fragmentation is going to become an issue on larger volumes with large audio, photo or video files so defrag regularly.
Its very good practice to seperate stuff really. I think leaving it in one big partition is not the best thing to do.
