Heat damaged VPCF11Z1E
profile.country.en_GB.title
dipatel17
Visitor
Hi
I own a Sony Vaio VPCF11Z1E and the wrist area is peeling, also the left click fails to work some times. I believe this is because the F11 gives off so much heat (Manufacture fault) where do i stand with this as it is out of warranty?
Message was edited by: dipatel17
1 REPLY 1
faabate
Explorer
Hi mate,
I am also experiencing the same annoying problem for a such expensive machine.
It is so heat that the wrist area are coming out and all wrinkly, and worse, the rubber is growing over the case edges. I think the only way is to replace this rubber for a new one, which might by rare to find or make a new one with another kind of material.
I still haven't tried yet. If I fix it I will reply back here.
Good lucky.
