Partagez votre expérience!
Hi,
Since yesterday, I can¿t hear music on my vaio anymore. I still hear the beeps of the menu¿s (so it can't be the headphone or the remote I guess) but no more music. AVLS is off, volume is on, so I can¿t figure out what the problem is. Anyone an idea?
Sometimes happens. Just reset the VP with that little hole under the screen in the bottom side.
ok, it's idd solved now
thanx!
