Hi JoeMs,
welcome to Club VAIO..
The following guide below should hopefully fix the problem..
It would be wise to back up your registry first, here is a GUIDE
Manual steps to delete the UpperFilters and LowerFilters registry values that can cause CD access problems
Warning other problems might occur if you modify the registry incorrectly. These problems might require that you reinstall your operating system. Modify the registry at your own risk.
To manually delete the UpperFilters and LowerFilters registry values, follow these steps:
First open the registry editor..
Press the windows key and the R key to open the Run box.
Then type Regedit in to the Run Box then click OK..
Press continue on the UAC window and the registry editor should open..
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Restart your Vaio.
or
alternatively save the CD Gone registry fix (attached below) to your hard drive and then double click to run..
Hi ellankih,
have you tried downloading the CDgone.reg fix from the post above (Click HERE ).?
Once downloaded follow the instructions to run..
Hi ellankih,
go to device manager do you still have an error code next to your CD/DVD drive.?
When you try to burn a DVD do you get an error message.?
Hi ellankih,
Hello, regarding Sony DW-56A (re-badged lite-on drive?)
There is a firmware upgrade to version 7 available via dell who use the same drive
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&&fileid=134618
Hi to all, this is my first post.
In response to your feedback reagrding drive problems, mine was fine until I updated my firmware, now I keep getting disc errors.
The program I use is convertx to dvd, my laptop is the Vaio VGN-AR51SU, My qustion is how can you downgrade your firmware? because from my experience you cannot.
Any help would be appreciated.
Regards
Mark
Hiya!
I'm having the same problem. I purchased my laptop 3months ago and all of a sudden the cd/dvd rom has disappeared from my computer. I ran a diagostic and it says I have not got an optical drive. At my wits end after several system restore and still no joy I made the decision to do a C:\ drive restore to original settings and still no luck.
I unfortunately I do not know what the cd/dvd rom make is as not at my laptop but I own a VGN-CS11S/Q. Any ideas? Or do you think it's a trip to the shop?
Many thanks,
Hi - first post
I have a vaio vgn-nr32s, which doesnt recognised cd's. It has no problem with dvd's and in device manager there are no problems listed. When a CD is in the drive it seems to try and read it but nothing happens. I've also tried reinstalling the drivers but no luck.
Hello,
I have Sony Vaio VGN FE31h. I have reinstalled Windows XP followed by all the drivers of sony Vaio downloaded from Vaio website. every thing is working fine now except I have one problem which is that my DVD/CD drive (MATSHITS DVD-RAM UJ-850S) is now only reading DVDs but does not read CD's anymore.
I think the drivers of DVD/CD drive have been installed by the window XP it self. I tried to locate drivers from VAIO's driver folder but couldnt find any. so I am letting it work with those default drivers' which cant read CDs
Please help what to do 😞
NOTE:
I had to format my hard disk due to a disk failure, and therefore I dont have any recovery parition any more..
I have BTW already tried the way to which includes removing Upperfilter and lowerfilter from rigistry, but that didnt work,
Pls anybody can help me?:
http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=62333
Sony put a restriction to his drive?
With preinstalled software all works ok, after clear vista install, the drive not work good.
