- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Leon,
Sony usually include some sort of DVD burning software. Have you got some sort of Roxio program in All Programs?
You don't say what model Vaio you have so I can't look it up for you. If you post your Vaio model, I'll have a look and see if you have a DVD burner included.
There are lots of good DVD burning programs but probably the most popular is NERO
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You're quite right, I've found Roxio on there and just giving it a whirl. It's a VGN-FE31Z btw.
I may look at Nero down the line though.
I had a quick look for my usb drive earlier as well and notice that I only have the following drives:
C:
E: memory stick (thanks for showing me where it is!)
F: dvd drive
That's it. When I remove the mass storage device it refers to the G: drive. Does this mean it's not set up if I can't see it? Sorry to be asking such basic questions.
Thanks,
Leon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It sounds like your card reader is not installing properly - did it come with a disc or is it a generic XP device.
Burning to DVD is different from using CDs. With the software you have you cannot drop files one at a time from explorer onto a DVD. (In Roxio you will find the 'Drag-to-Disc' feature greyed out - you have to pay more for that!)
In Roxio Digital Home click on 'Data -> Data Disc -> Add Data' and drag the files or directories you want to back up one by one into the explorer type box. You then have to burn them all in one go!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Bought it off laptops direct and it came with no cd's (other than antivirus). Instead they installed everything for me so it was ready to go from the time it arrived.
I've not tried plugging anything else into the usb ports so couldn't say if this problem is just relating to a mass storage device or more widespread.
I've checked device manager and it suggests everything is running ok. Any thoughts?
Thanks,
Leon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I have had my
Vaio Notebook VGN-FE31Z
since October - I bought it about two days after release - and this is the second time I have had a problem with the CD/DVD drive. It is aMatshita DVD-RAM UJ-850S
. I have tried Uninstalling and Reinstalling it, as the troubleshooter tells me, but i still have the same error message:Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Last time, I phoned up Vaio Support, and to be fair they were extremely helpful, but unfortunately I had to completely reformat my drive, and reinstall Windows etc etc, and from then (about mid-November) until today, I had no further problems. As far as I can remember, this is exactly the same problem as then, and I am understandably unwilling to reformat everything again. Moreover, I am really unimpressed that I have had this many problems (the DVD malfunction isn't the only thing that's gone wrong) and I doubt I will buy another Vaio after this one. While the Customer Service is excellent, I feel the product should be much more reliable considering the cost and reputation of the brand.
Anyway... enough of a rant! If anyone can help, I will be extremely grateful.
Thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I seem to be having the same problem. I keep getting the message that there is no DVD drive installed when starting programs requesting the original CD in the drive. The DVD drive is not showing in the in "Explorer". When entering the Device Manager I see the DVD drive with a "!" and the error code 10. What can I do? Thanks in advance for any suggestions.
Matshita DVD-RAM UJ-850S ATA Device
Sony Vaio VGN-FE41S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Mike,
If you look back through this thread you will find a simple solution to a Code 39 error.
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=39917
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You know what amazes me most? 135+ posts and 17k+ views. Isn't it time Sony made a change?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi!
I'm new here, but I have my laptop for about 6 months now. At first, everything was working fine, but lately my DVD RW drive started to give me headaches.
I have a VGN-FE21H with Sony DVD DW-G520A drive. The drive started to read and write very slow.
Max. read speed for CD or DVD was around 1,5 MB/s same with write speed (with buffer level jumping from 5 to 90%, using Nero).
After a couple of days searching the web, I managed to fix this "problem".
First thing I noticed was that everyone was telling ppl with similar problems to "go turn on the DMA mode on the IDE channel the drive was on" or "go update your firmware".
The problem was that no matter what I did, the drive still wasn't using the DMA mode.
Second problem was finding the darn firmware. On the Sony support, there are only MatSHITa and Pioneer FWs for my Vaio model, but it has a Sony drive (shame on you, Sony).
I finally found a firmware version GFS3 (original in my drive was GFS1) at:
ftp://ftp.vaio.sony.co.jp/pub/vaio/download/SP-011881-04/SOFOPD-01188104-UN.exe
Install is in Japanese only... Follow the same instructions that can be found on the support page.
Flashed my drive and it works fine now (DMA is on and everything, full read/write speed...).
In case anyone wants to try the same, check your drive's FW version
(you can do that with Nero Info Tool http://www.nero.com/nero6/eng/Info_Tool.html)
There are two versions, one being called GFS and the other GYS. Update with same version only (ex. GFS1 to GFS3 or GYS1 to GYS4).
You can find GYS4 here: http://download.opendrivers.com/drv/cd-rom/sony/GYS4WIN.EXE
In case you want to, you can DL this tool and backup your current firmware:
http://upload.cdfreaks.com/ftools/LtnFW.zip
DO ALL THIS AT YOUR OWN RISK.
Hope this helps someone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After a recent update of Vista, my DVD drive (QSI SDW-086)has stopped working. I have tried system restore to 2 differnet restore points prior to the update, but both times the restore has failed (unknown error during restore - very helpful!). I then tried updating the driver but Windows said the most up-to-date verion was already installed. I have then unisntalled the driver, downloaded a new driver from the VAIO website - which would not install - error = you dont have admin rights (I do!) or no device is recognised! When I lokk in device manager, the messgae is: windows cannot load the device driver for this device, the driver may be corrupted or missing (code 39).
Any advice on how to proceed would be great, as my computer is essentially useless at the moment!!
Many thanks
PS - I have a neighbour with the same model VAIO - could I copy the driver from his machine?
