IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 RESPOSTAS 403
profile.country.en_GB.title
Glencoe1952
Visitante
Hi guys I need help. I've never been on one of these forums before (age is a terrible thing) and I'm unsure just exactly what to do , however here goes.  My problem occurs when I am trying to create a AVCHD disc. Everything appears to be progressing well until an error message comes up during the authoring process. The error is 0070-0012-8019-00008000. Regards Len
profile.country.en_NL.title
adoador5
Visitante
hello,
i have also a VGN-FW21Z and have a problem with my optical drive - 'can't read cd/dvd'.
did you get any solution? if so, would you mind sharing it to me?
many thanks,
ador
profile.country.fr_FR.title
Lisaby
Visitante
I tried all the fixes proposed by Sony, including Microsoft hardware fixes, but none worked.
Accordingly, I decided to go the Recovery Disk route.
But how was I to read the Recovery Disk if the DVD reader wasn't working?
Sony gave me a solution to this problem, involving the Boot Menu.
The fact that the Boot Menu approach permitted my DVD reader to read the Recovery Disk gave me hope that the underlying problem was software based and not a hardware problem.  This hope was realised.
By extension, I would recommend all users having this problem to see if they can make the DVD reader work through the Boot Menu route.  If it works, they can assume that the problem is software based.  If it doesn't work, they can assume that there is a hardware problem with the reader.
As with all uses of the Recovery Disk, it took me the better part of a week before I had returned my PC to its previous status - despite having done both a Windows back-up and a back up with the software I usually use (ffBackUp).
Despite this bother, it was certainly worth doing in my case, because I travel with my notebook.  Better to fix the problem at home where I had copies of the Recovery Disk and access to Sony's advice than to find myself in the situation of absolutely needing to read a DVD on a trip and not being able to do so.
For a desktop, it might be easier to buy an external DVD reader and not bothering to try to fix the problem.
Jonteknik
Visitante
I have a VGN-N11M/W with DVD drive AW Q540A
The DVD drive has stopped working and I'm getting error code 39. Any ideas how I get it starting again, I can't find the driver/firmware anywhere on line.
Thanks
Jon
Lisaby
Visitante
Have you read my post of 5th March?
I thought that it pretty well covered the issue.
Plase let me know if you have more questions.
Lisaby
Blencogo
Hi Jon,
A small Registry edit will fix your problem.  Be careful and don't change anything else while you are in the Registry.
1.Click Start > Run and type REGEDIT and hit enter.
2. Navigate to –
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
and  highlight it.  Then locate UpperFilters in the right hand window, (if  it exists) right click on this and select Delete and then OK.
3. Under the same Registry Key locate LowerFilters, (if it exists) right click on this and select Delete and then OK.
4. Quit Registry Editor and re-boot the computer, new registry values will be created that will hopefully cure the problem.
After  you remove the Upperfilters value and the Lowerfilters value, you may  possibly need to re-install your burning software – but not necessarily.
Good Luck !
:wink:
Lisaby
Visitante
We all owe a debt of thanks to Blencogo for his guidance on this issue, but - in my case - his fix didn't cure my problem, thus the need to restore the hard disk as described above.
havers58
Visitante
Hi,
I have a VPCEB3F4E.
In the last couple of days I have had driver issues on my CD-Rom Drive and CDC Serial and my Samsung phone GT-I9100.
I have tried uninstalling and restarting, buut errors do not clear.
The CD Driver error is Code 39
CDC Serial error is Code 28
GT-I9100 error is Code 10
I would be grateful for any help or advise...hoping its not terminal!!
rich912
Participante
Hi havres58,
For the CD driver error code 39 see Blencogo’s post – two above yours...
Rich
Go n-éirí an bóthar leat
celavey
Visitante
Wow.. Awesome information. Thanks a lot for sharing it.. Got a lot of problems with my CD driver lately.
