My PCG 31111M volume is not loud enough on loudspeakers - but fine on headphones.
Anyone else experienced this problem?
Any known solution?
You are quoting an invalid model - I think you have the chassis style which may cover several models. I guess it is a Z-Series Vaio.
You can try increasing the default speaker level in the bios or find a program that has some form of pre-amp like VLC Media Player but any increase in volume will only be small.
