I have a sony VAIO model VGN-SZ3XWP/C and it doesnt have any sounds from the internal speakers or when I plug in headphones. have tried downloading a audio driver but cant find it for this specific model. Have tried all the troubleshooting options.
Seems I have come to basically my last resort which is to ask others! Not sure if other people have this problem, is it fixable?
Are you still using Windows XP?
If so you will find the Original Drivers Package here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-SZ3XWP_C
Try reinstalling the Audio Drivers. You will have to reinstall the UAA High Definition Audio Class Driver first as XP does not support HD Audio. If you cannot find this in the Drivers Package, then download it from here: -
http://support.microsoft.com/kb/888111
hi i do have a same problem, in my sony vaio window 7 professional
