Problems after un-installing IE9
profile.country.en_FI.title
trpalan
Visitante
I recently installed Internet Explorer 9 by mistake - thinking it was a normal update, not realising that it was just a beta version - I didn't like it and went through the procedure of uninstalling the update in order to get back to IE8. Ever since then I've had problems.
If I start IE8, then my Windows Live Mail won't connect to my servers to download mail. If I start the mail program first and download my mail then IE8 won't load any webpages just keeps showing trying to connect. My internet connection is fine - only problems with these applciations.
Any ideas why and any solutions?
Thanks!
1 RESPOSTA 1
profile.country.en_GB.title
MurdoD
Visitante
Not alone with this problem.
Try removing IE8 and re-installing it:
Step 1: To uninstall Internet Explorer 8, follow these steps:
  • a. Close all programs.
  • b. Click Start, and then click Control Panel.
  • c. Click Programs and Features.
  • d. In the tasks pane, click Turn Windows features on or off.
  • e. In the list of windows features, clear the check box next to Internet Explorer 8.
  • f. You receive a warning message in a pop-up window. Click Yes.
  • g. Internet Explorer 8 will now be uninstalled. The system will restart after the installation.
Step 2: Re-Install IE8
  • h. Repeat the steps a- d
  • i. In the list of windows features, check the box next to Internet Explorer 8.
  • j. You receive a warning message in a pop-up window. Click Yes.
  • k. Internet Explorer 8 will now be re-installed. The system will restart after the installation.
Let me know how you get on!
