im wandering if this ting will werk with a par of Sony WH-1000XM2 on my xbox one https://www.amazon.co.uk/dp/B078K2BBKH/ref=asc_df_B078K2BBKH50382712/?tag=idex-21&creative=22374&cre...
Hi @bullen_1987,
it won't work, since the "headphone" side of the cable (with the microphone) has a 2.5mm TRS audio jack, while your headphones need a 3.5mm TRS connector.
- Nic
Hi @bullen_1987,
it has the right connectors on the headphone end at least.
Where do you want to use it on - PC/PlayStation Controller?
- Nic
