VAIO Pro 13 Wifi problems
Antti111
Explorer
Does anybody have solution how to fix VAIO Wifi ?
I have new VAIO with all Win 8.1 and updates and new BIOS installed but Wifi conection is really bad. If you go just couple meters a way from the AP Wifi connection is useless.
I have read many complaints about the Wifi but how to fix it, is there a solution ?
0 REPLIES 0
