My VAIO SVE1513A4E refuses to boot from anything other than the HDD, even though I am using a USB stick which I know is bootable (on a DELL PC). Before I get the usual suggestions of F2, F11, ASSIST Button etc. I have tried them and none work, even changing the boot sequence in BIOS fails to make any difference. Anyone had a similar experience?
Thanks, but somehow I did manage to get the machine to boot to the USB drive. Only by changing boot options in BIOS though, not using the 'Assist' button.
Hi DrMopp,
That's strange. If you contact Sony Support about your VAIO SVE1513A4E, they should be able to assist you further with this.
Best wishes,
Pascale
