Hi,
from yesterday morning I have problem with wireless conection on my notebook VAIO VPCYB2M1E.
The switch in VAIO Smart Network application is disabled and when I try to change, I get message: Turn on WIRELESS switch of VAIO computer and try again.
(Screenshot is attached.)
I haven't any wirelles switch on notebook. Exists any keyboard shortcut?
How can I solve it? Thanks :-).
Hi NanikCZ,
I'm not familiar with your model and I assume you mean VPCYB2M1E ?
If there is no physical external switch then it would normally be a combination of Fn + F2 (or the function key with an antenna symbol). That said I thought most Vaios have an external switch.
Rich
Hi rich912,
thanks. Yes, it was typing error - I mean VPCYB2M1E. I'm so sorry, the black switch is from the bottom of notebook - I didn't see it.
Problem is solved. Thanks so much :-).
