Hello, I'm searching for a pair of headphone that is 2 in 1 built: with walkman (playable audio files stored on it) and as a simple headphone to be able to listen music/movies from my other devices: PC, laptop, etc... I see https://www.sony.com/electronics/walkman/nwz-ws610-series/buy would be what I need, but does it behave as basic headphone to connect it to my PC/laptop to watch movies? If yes, then can it be purchased from Romania? Thanks!
Hi there,
Welcome to the Sony Community.
As this is the UK Community for all things Sony Electronics, I would recommend posting your question over in the Sony Romania forum here for further help and advice.
Best wishes,
Sean Mc
Thank you Sean,
I was just hoping for a simple recommendation (or more recommendations, of course), regardless where I'm from or what flag this community has.
When I created my account I think I already selected my country, and then I simple listed the question
which appears to be listed here, and as everything was in En, I also wrote the questin in same language.
But, thanks anyway, this changed my mind completely.
Once again: very helpful reply!
Kind Regards
