green led on the right side
SOLUCIONADO
profile.country.de_DE.title
jeffersonairplay
Visitante
hello, i hope you can me help. i have my tablet s for one day and in standby is a green led on the right side of the tablet.(it is not for charging the battary) what is it and how can i delete it for ever?
thanks
1 SOLUÇÃO ACEITE
Soluções aceites
profile.country.en_GB.title
anmanto77
Visitante
there are 2 green lights on the right hand side of the tablet s, one is for the charging level ( orange for charging and turns green for fully charged and the other green light comes on to inform you that you have recieved an email )
4 RESPOSTAS 4
anmanto77
Visitante
thejudge
correct, though it is not documented anywhere from what I can tell.  it is quite bright as well.
jeffersonairplay
Visitante
thankyou for help
profile.country.nl_NL.title
breedBenR
The single, multicolor-able led is standard on all android devices. You can probably set color in the various mail, chat, messaging, battery satus etc apps that you use (deep in the settings menus, preinstalled and self downloaded ones alike). There may be an app that can also set the brightness (i have not found it though).
