Battery problem, how much does the battery last?
Noria
Visitor
I just buy the xa1 ultra, its new anda only has one month of use and the battery doesn't last mucho a 100% with Stamina 6hrs -.-.
Does anyone now a solution?, can I make use oh the garantty?
5 REPLIES 5
Uliwooly
@Noria
I don't think that you have to send it in for repair, follow this steps and post the screenshots
Provide the following screenshots
follow the steps
Charge the phone 100%
use it as you normally would
once the battery has reached 10%
Settings
Battery
take a screenshot of this
Menu
Consuming apps
Show all consuming apps
take screenshots of the list
tap on the top 5 items/apps on the list and take screenshots of each
post them all here
Smiert
Visitor
My Bluetooth 43% !!!
Unbelievable bad phone!
Uliwooly
@Smiert
Do provide all the screenshots to have a better context.
deltamind
Visitor
I've done factory reset. I've used my phone till it died at 0%.
Estep16
Visitor
I would highly recommend doing a software repair with Xperia Companion. Backup everything first, this will be a total reset.
Jag tror det verkligen behövs pga den dåliga Oreo uppgradering. Hoppas att v8.1 kommer lösa de här problemen i framtiden.
