- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
USB Storage is Restricted
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @Kara28M,
Welcome to the community,
This generally happens if something has added a security policy to the device, in most cases this would be a work email, are you using a work email on the handset?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Did this only occur after downloading and installing AVG on the device or are you aware of any changes that have occurred since the last time you used the function?
The error message itself gives the answer, there is a security restriction on this device, and this has likely been actioned by some application on the handset that has admin rights. AVG just happens to get Admin rights upon install.
Maybe try removing AVG from the device and testing.
Let me know.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
i have the same issue. my previous phone with Android 6 version is ok. only my current phone which is updated to Android 7 has the problem. the security patch might be the issue..... it seems like a common problem that we all have.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have the same problem, pls help
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
SOLUTION for me was:
I had encrypted my phone and sd card.
To my mind, the issue is sd card. The clue is "security policy".
Deactivate encryption for/on sd card, and then reboot your phone.
Then detect USB as usual.
After that (after you use your USB) you can reactivate encryption on sd card.
