annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Small Apps XZ
Ibrahim11
Visiteur
Small Apps XZ
got my XZ a while a go. i didn't notice that it doesn't have the small apps like the Z3+, till i wanted to screenshot a post. looked over the settings, couldn't find anything regarding the small apps.
anyone knows how to get this feature?
Balises (3)
11 RÉPONSES 11
Uliwooly
The small apps have been removed, you can take screenshots by pressing the power & volume down button at the same time
Lord_viridis
Screenshot is also still in the quick power menu when holding the power button.
Ibrahim11
Visiteur
@uliwooly i tried this. did not work!
Ibrahim11
Visiteur
@viridis i know its there. but I'm wondering if there's any faster way to do it? like the small apps.
Sunking1011
Contributeur
They no doubt removed the small apps because of the impending Nougat update.
Uliwooly
It does work, perhaps you are not pressing at the same time and/or you are not holding the keys for a second
Lord_viridis
Yep, works here
Ibrahim11
Visiteur
@uliwooly it works.. looks like i wasn't holding it for a second.. thanks for your comment.
Uliwooly
Anytime
