Dear Sony ,
I need MSDS Data sheet for Xperia z5 premium battery for airliner courier , so i can give a gift to my brother .
Solved! Go to Solution.
I dunno if Sony is providing Material Safety Data Sheets, but I think that their Environmental Declaration document can have similar data. Check if the airlines can use it instead:
http://www-support-downloads.sonymobile.com/e6853/environmental%20E6853_2015.pdf
Thank you for kind reply ,
I need this kind of document from sony ,i am sending the sample document link for you reference .
I've requested more info about this matter and I'll let you know if I have them.
Also consider contacting your airline company and point out that the phone has a regular battery like any other smart phone and it should be sharing the same security and safety precautions as any other device with the same battery.
