GTK-XB60 Speaker Don't power up with the power chord
profile.country.PT.title
parsxeal
Novo
The speaker battery has no charge, when I press "power up" it blinks 3 times (charge light). wich is expected behavior when you have no charge. The problem is that it doesn't do anything when I connect it to the power plug. The speaker doesn't power up or charge. There is no light in the charge light.
Marcas (2)
1 RESPOSTA 1
HannahEd01
Hey parsxeal,
Check that the AC power cord is connected securely, or try a different main.
If the issue is still there, it will need to be sent for repair. You can use Sony's authorised service centre locator: https://bit.ly/3tMmxVC
