Low headphone volume with "Dolby Sound" enabled
No-name
Explorer
When using headphones, max volume output is too low with Dolby Sound enabled, compared to it disabled. Can it be increased in future updates, to ensure it's at least as loud as with Dolby disabled, if not louder?
Don't want to disable it because it sounds much better and louder with loudspeakers when enabled. However, this loudness boost should be reflected in headphones too.
3 REPLIES 3
Anonymous
Not applicable
Hey @No-name
Can you provide the full model of your headphones?
No-name
Explorer
any brand/model.
Anonymous
Not applicable
Hey @No-name are you having this problem with a specific headset as it seems that you are talking about a specific model is that's the case can you tell us the model as shown here.
