Hi
Recently I've encountered problems with my fingerprint manager. Since the update it has completely gone from my settings menu on my Xperia 5. I spoke to someone from the team and they suggested backing up my phone and software repairing my phone. This didn't help one bit. And also erased everything without it backing up. Has anyone else experienced this with the fingerprint manager?
I got the same problem
It is a hardware problem. A had the same problem. Phone need repairing by the warranty
Hi mine is missing as well did anyone cure it?
I have the exact same problem, now it won't accept my fingerprint login
Wow this worked for me too. Thank you
Had the same issue this morning, it happen when I switched off the phone. When turned it on I soon discovered that the fingerprint manager had totally vanished and the sensor was not accepting and input what so ever!
After a brief panic and reading various web pages I decided to power down the phone again (fully turn off, not just a restart) and leave it for 30 seconds. When I rebooted the phone I tried the fingerprint sensor to unlock the phone, I know that after it has been turned off the sensor doesn't unlock the phone but prompts you to input your pin which it did. Unlocked the phone with the pin and the fingerprint manager had returned!
Hope this simple fix works for you as it did for me.
It is a temporary solution. The problem will be return. It is a hard are problem with fingerprint sensor
Over a week now and the problem has not returned, looking good thus far.
