Android 10 nu LTe+ maar geen 4G meer?
profile.country.NL.title
Michelxperia10.
Novo
Sinds mijn xperia10+ Android10 heeft heb ik geen 4G meer maar LTE+ Bij mijn provider Ben begrijpen ze het niet en Sony snapt niet hoe dat kan. Iemand een idee?
1 RESPOSTA 1
Strampke
Op mijn telefoon staat soms 4G, soms LTE en soms LTE+, afhankelijk waar ik ben.
Eigenlijk nooit op gelet.
Ik zal eens kijken wat en wanneer.
Inmiddels ook iets gevonden op youtube.
De providers worstelen er ook mee.
Dit vond ik op het internet.
What is LTE?
LTE stands for Long-term Evolution, and isn’t as much a technology as it is the path followed to achieve 4G speeds. For a long time, when your phone displayed the “4G” symbol in the upper right corner, it didn’t really mean it. When the ITU-R set the minimum speeds for 4G, they were a bit unreachable, despite the amount of money tech manufacturers put into achieving them. In response, the regulating body decided that LTE, the name given to the technology used in pursuit of those standards, could be labeled as 4G if it provided a substantial improvement over the 3G technology.
Immediately networks began advertising their connections as 4G LTE, a marketing technique that allowed them to claim next-gen connectivity without having to reach the actual required number first. (It would be like the U.S. claiming they had landed on the moon because they got pretty close and the spaceship that got them there was a lot better than the previous ship.) It’s not entirely trickery though, despite inconsistent speeds depending on location and network, the difference between 3G and 4G is immediately noticeable.
To make matters more confusing, you’ll also likely come across LTE-A at some point. This stands for Long-term Evolution Advanced, and it takes us a step closer to proper 4G. It offers faster speeds and greater stability than normal LTE. It’s also backward compatible and works by aggregating channels, so instead of connecting to the strongest signal in your vicinity, you can download data from multiple sources at the same time.
Speed
So the real question is, can you feel a difference between 4G and LTE networks? Is the speed of loading a page or downloading an app on your handheld device a lot faster if you have LTE technology built in? Probably not, unless you live in the right area. While the difference between slower 3G networks and new 4G or LTE networks is certainly very noticeable, many of the 4G and “true 4G” networks have upload and download speeds that are almost identical. The rollout of LTE-A has made a difference for some, but your mileage may vary. LTE-A was the fastest connection available for wireless networks for a while there, but we’re starting to see 5G networks go live in a handful of cities.
