Great stuff - Thanks.
I've given up with email support. They all just try to blame other people - Sonos, Netflix, etc. Their TVs are faultless according to them, it seems!
Don't worry, please be assured they appreciate the feedback on these forums, either positive or negative.
If they don't know it's 'broke' then they can't fix it
Hey everyone, I've been reading through and noticed alot of unhappy people. I seem to be having alot of the same problems. Only found out only today that you hold the power button on the remote to reboot the TV. I swear I didn't see that in any help files or the manual lol.Seems to cure all issues though for me, apart from the lip sync issue, which seems to go away once simulated surround is switched off. I don't think it worked very well anyway.
Just a quick mention, I did notice the TV was using more 75% of its RAM of 2GB. I didn't have any big apps open either. seems odd to me. Would be nice if the TV went through an app refresh during standby or when launching TV. Maybe that would stop the laggy guide. Btw, how come the colour buttons aren't enabled on the guide. red for page down, green for page up, yellow for +24hours etc. Its very tedious scrolling through one by one.
Honestly, bugs aside which i'm sure will get fixed, anybody else notice KOTOR in the list of games?
i got optical working, just set tsound to come out of external speakers only, otherwise it will output in stereo only
My worry is 2Gb isn't enough for Android TV. Especially so with the current memory leak.
I'm also amazed at the amount of apps, around 180, even before installing any myself. Loads are running that I see no point in so I imagine that's most of the ram gone before you even start.
I've started rebooting my TV every night now to keep performance levels up. I'm gonna keep it until the next firmware but if that doesn't sort things out then Amazon will be getting it back.
Getting tired of this now. Tried to watch a few Youtube videos tonight and it was frustrating as hell.
Why would 2 gb memory not be enough? Mobile phones these days also come with 2 gb and those work perfectly fine. I dont think this is a memory issue *****, I believe it needs better CPU/GPU optimizations and fixes for all the mentioned things
Maybe right now 2Gb is ok but think of what is still to come - Youview, HDD recording, more apps, etc. I hope performance doesn't suffer a year or so down the road.
4Gb will be standard in mobiles from next year.
Also Android 5.0 has been a memory hog since day one. I'm still hoping it will be resolved but 4Gb would have certainly put my mind at ease a bit!
Installing apps has nothing to do with the memory, that has to do with HD Space, and the TV has 8gb by itself and I think you can expand that by connecting a USB HD or USB Stick, so, that also shouldnt be a problem.
Also with upcoming Android M things should improve a lot
