@rocdefrost wrote:Since yesterday I am the (not yet) proud owner of a KDL65W855. Amonst others I have these two issues:
- I only receive SD tv channels, no HD. My cable provider (Ziggo in Utrechte the Netherlands) does provide HD (on my old tv, my tv in de bed room). Who can help me?
Thanks!
Re HD channels, are you using a CI+ module ? It sounds as though you are only receiving the "free" channels, not the encoded (=HD) ones....
Also, when scanning/programming channels, you need to select "other" as provider
Yes i am using a CI+ module.
I noticed on Tuesday and Wednesday night while watching Ray Donovan and Wayward ***** that the screen was dimming in dark scenes and brighten in light. Immediately I thought the Sony was up to no good again, it must of turned on the ambient light sensor for whatever reason.
So hit the action menu button (few moments later) the menu pops up, still not loading all the options properly and being ropey. Went to Picture and saw straight away that the light sensor setting was off!
Anybody else notice the screen dimming and lighting at night while viewing, bit still have sensor turned off?
Why was the word "*****" removed from the comment I just posted? lol
Same file played fine using the TVs own Video player. I then noticed a plex app update, so updated it and restarted the TV and, so far, playback seems ok. Controls are a bit clunky using the TV remote, something I guess I need to get used to.
Still got a lot of learning to do with PLEX, to improve the experience and tune to my needs (lots of menus that I don't think I need to see, so hopefully some options I can turn off).
Have installed Kodi too, menus seem slicker than PLEX at the moment but I need to see if I can find a skin I like for Kodi, I really wish someone would produce a Boxee skin for Kodi (as my family all know how to use Boxee!).
@VolkersK wrote:
@rocdefrost
I had the issue where my hd channels were located higher up in the channel list (901+ from the top of my head). When searching for channels I had chosen UPC. After searching for channels again but this time selecting Other (I think..) the hd channels showed up where they should.
yep, that's normal. (former) UPC and Ziggo have different sequence of channels....
Thanks. I will try it tonight!
