I wish I had known about this additional resetting procedure for the touchpad remote last month after mine stopped working. I could only find the pairing options that didn't work. I think this highlights a need for an old fashioned printed manual with trouble shooting options for these complex tvs as well as a fuller description of the various options in each of the settings menus. referring to the online manual is not always easy to do when setting things up.
I have KDL50W805CBU. A week after the latest update these are the results.
Kodai works no lip synch or speed issues. The audio levels seems to have improved. Response is faster with the TV remote. No problem with casting.
TV and Aux Audio system switches off immediately when the off button is pressed.
The following problems still persist which i hope will be solved in the next update.
HDD recording
Momentary blank screen when the guide button is pressed.
About 30s delay for the aux audio device to switch on even though they are connected via HDMI ARC.
Repeated on screen message stating 'screen format: full' while playing from Blu Ray.
I have not checked all the functions
Decided I'm gonna take a hit and sell my 809C. Too many little niggly problems from turning itself on to audio out of sync and bigger issues especially when in using it with my PS4. This is probably my first and last Sony TV. Very disappointing.
@djadrianc wrote:
@mark-bo
Here's the manual you're looking for.
http://helpguide.sony.net/tv/caep1/v1/en/print.html
Available on this support page
http://concierge.sony.co.uk/support/EN/product/KD-55X8509C/?XID=M:Support_by_Sony_Applicatio
Thanks Adrian
Sent from my Mobile
Thanks Adrian for the Link
I was interested in Shalendran's comment about the issues with the Android TVs. I also experience the brief blank screen when hitting the guide button but I am assuming that the Youview guide will be completely different (similar to that on the BT TV system) when released in the early November. I don't have a blu ray player so can't comment on the 'screen format' message although have seen in briefly on some inputs. HDD recording is supposed to be available 'before 24th December' according to Sony site - we will see as they do say 'release date ... may change'!
In particular the note about the excessive 30 sec delay for sound to start on the HDMI/ARC audio device was of interest to me. I have experienced what appears to be a similar issue with my KD43X8309 and XT1 system since their purchase in May (see my recent topic titled 'Bravia KD43X8309 and XT1 sound start time issue' which details the problem I have). The retailer where I purchased the equipment cannot understand the problem (and has swapped out the devices with no improvement) and both he and I have raised with Sony with no progress yet.
I now leave my XT1 powered on as a 'temporary' circumvention for this annoying issue so that sound starts immediately the TV picture appears, but this should not be necessary.
As you have a similar sounding problem with a different model TV it may suggest a more fundamental issue somewhere. What audio device do you have? I suspect there are more users out there who suffer with this problem and it would be of interest to know of similar experiences to know how widespread the problem is.
It will be interesting to see how you guys get on in UK with You view update , will it put more of a strain on already suspect processor, or maybe it will be the sweetener everyone has been waiting on which will make the other bugs bearable.
I am in Ireland so I miss out on You view altogether and we don't have access to RTE player only TV3 which is like watching Lego , I have to say I am very jealous of your catch up services.
I am still going to wait until after the HDD update to decide whether this TV is worth buying or wait for the 2016 model which I only presume will have an updated more powerful processor with greater storage.
All in all after following this thread it appears the 2015 range is gradually getting better but still a bit of a basket case , decisions decisions ( hugely discounted 2015 v fully functional expensive 2016 )
Is the processor really going to be an issue for YouView? My X83 copes well enough with IPlayer, YouTube and Netflix.
I would add that my TV is still behaving well post-update. I get the very occasional system hang but nothing like how it used to be. This may seem controversial, and I note that many others are still having unacceptable problems, but I'm definitely not considering returning my TV now. I most definitely was before the update!
As such it does make wonder if somehow the age of the device is a factor? Have there been any hardware revisions since release? Otherwise perhaps the accrual of "cruft" by the OS over time is a factor, hence the advice on factory resets? Maybe the earlier OS builds were more liable to not clear up after themselves?
FWIW I ordered my TV on August 29th and had it delivered on September 1st. Are other more recent adopters no longer seeing the problems, or have I somehow just got lucky?
I was thinking of buying the 43X 8309 but have doubts given all the issues raised in this forum. I would be using the TV connected to a TiVo box and occasional blu Ray use. I would not have any external audio etc.Has anyone any experience of a similar set up?
