I got a hold of the full version... Edited my channel list, read it back to the set; the set just changed it again; deleting at least one wanted channel, 'un-renaming' channels I'd customised... And adding-back some 17 random foreign language channels!
These are stations that would not have been even ON the channel list I was working on; having viewed the raw XML via dreamweaver's code window...
Having to use an external program to do something basic is bad enough... But the set just won't retain that information and seems to 'do what it likes'!
Hallo everyone,
There's some other options to avoid channel refreshing when receiving your channel via satellite.
Can you please check if those are disabled as well?
Thanks a lot in advance
Hi - first post here - apologies if what I'm going to ask has been covered previously - but a lot to read through so I haven't - sorry. Purchased new Sony (standard HD) Android TV (KDL43W809CBU) about a week ago and got some concerns and problems - but searching and finding this forum - I'm not the first and that has got me worried.
Basic problem is that yesterday I was in the Youview guide and selected something against a programme (I think it was Watch on Demand or something - I can't remember). Anyway the Youview guide now does not display programe information - all I get for all channels is Information Not Available - and for any selected programme I get Loading...
I've done basic switch off TV and retune etc. But can't get details back. Help,.
But in addition to that I've noticed a 'lip synch' issue between picture and sound - and seems it's a common issue?
I'm also not convinced by picture quality - so for instance a seem to get a lot of smearing when watching football that I don't get with my 4yr old Panasonic...is thaty just me?
And the picture from my feed from my Sky HD+ box is rubbish (wavy background 'interference' over all of screen (though that might just be feed and nothing to do with the TV)
And so on.
And reading of all the issues and problems here I'm thinking that I'll just take it back and tell them I'm not happy.
Is it worth persevering trying to get things sorted or hoping I can sort things or they will improve? I have no great attachment to Sony so if I'm just going to be disappontedf maybe I should take it back. We don't spend much on technology - and this is by far the most we've ever spent on anything - never mind a TV - and I am so disappointed.
HenryHallsDanceBand -
I have the same model, but don't experience a lot of the issues that some users do.
Lip sync is only an issue on Youtube for me, everything else syncs fine via my AV receiver via ARC
I don't use youview as I'm running Sky HD - the picture quality from my sky feed is crystal clear for fast moving images like sports (as is the feed from any other external source e.g. BluRay, PS4, PS3 and even the Wii).
You might have a faulty set if you are getting wavy lines from the sky feed - presume you've tried alternate HDMI port and/or cable as well.
If you are already unhappy then you may want to get rid of this quick while you still have the returns policy in you favour.
Hope this helps.
@andipr Thanks for that. My TV is in a back room and remote from my Sky HD+ box. I'll try connecting the TV direct to the Box and see how I get on. I may have to move it in any case as I need to install a Sky Magic Eye to be able to access and control the box from the back room (which would mean I wouldn't be using Youview in any case) - but I may have issues with that even given my aeriel set up with boosters being in the way (coaxial from the Sky HD box to all rooms in the hose) Picture quality from a BlueRay plugged into via HDMI looks great. Too many things...:(
@Triswillmott I'm close to that. BTW - can I just take a TV back and say "I don't like it - I want my money back?"
Hi everyone,
2015 Bravia Android TV Issues Can someone repost this onto that thread please. I have to post this as a new thread because, for some continuing reason, I have no "Reply" buttons to the threads I can read.
Last evening, I watched a 4K UHD example broadcast from a European station via satellite for a few minutes - a bit like the Sky UHD one. When switching channels to the next station, the picture is ultra zoomed-in. The result is that the picture occupies the right hand half of the screen, approximately, and the picture that is there is ultra zoomed in such that only about the top left 10-15%% of the picture is actually visible; like the newsreader's right ear and a bit of neck. This is made up of low res lines and then persists on all channels; it can be removed only by unplugging.
Another interesting quirk for the Sony Boffins to ignore....?
Regards,
PA
peterk_1 wrote: I think this should be forked to a new thread
Looking at the links to the software it would appear that Sony have licensed a restricted(?) version of "SetEditSony 1.12" settings editor here http://setedit.de/SetEdit.php?spr=2&Editor=140 . AFAIK this software works by importing the Sony xml file to its own internal format and having finished editing the channels are exported back to the sony xml file. Dependant on the "resrtictions" it may be possible to download a suitable channel list from one of the "satellite" forums and export it in "Sony" format. (The core software is common to all supported receivers and DLL's are added for each receiver you want settings files for)
I haven't used the software for maybe 5 years and my memory isn't that good but I think I had problems with removing channels - All channels held in a master list and when the export file is created all channels are exported with "deleted" channels flagged?????? and the tv is ignoring/overwriting the flag. There's a proper help file at http://www.seteditfiles.de/SetEditSony/SetEditSony_en.pdf that may contain a "permanent delete".
The settings file can be shared so sharing via email might help users
I note that "...and the tv is ignoring/overwriting the flag...". Therefore am not sure if this would mean that, for terrestrial digital too, setting Favourite_n as the Category shown in the Channel Guide would on its own be any use, even if Peter_S's channel list updates were to be disabled.
SetEditSony (is there a download somewhere for a free version?) is certainly interesting because it seems to have brought out what might be going on, but guess it is unlikely to be fathomable and practical for most users.
Oh, and is there any chance we could also have 'save all settings' ?
Channel List Problems
1.) Peculiarities, as above, of the way Channel Lists and Favourites can be edited, saved, and set up, and mainly that they are liable to self modification. These are potentially the most useful features so perhaps this could all be re-organised and properly documented.
2.) We find that this one has not after all been be resolved by the 10 Dec Update:-
Upon returning to watch Tv, the screening of, or repeated display of, the Channel List or, if a new channel has been selected, of the previously tuned channel.
This is still present after a Factory Reset and seems crude and unsatisfactory, especially when the irregular process behind it may be contributing to variable delays while switching channels.
3.) Pressing buttons Prog+ and Prog- doesn't result in page up/down
4.) Not sure if it helps that we have disabled the commercial apps, but the Information screen with Related Content, is very useful. However there is a snag involving order of the headings, being 'Details', then 'Cast/Crew' and last, 'Related Content'.
If there is any info about the 'Cast/Crew' the highlight moves down into that section, when it has to be directed up again to go to the more useful 'Related Content', so perhaps this could be dealt with and/or the order changed.
5.) 'Discover' is great!
