Last few days (I presume since the recent update), the picture I've got set for Sky+ seems to to be shifting from lighter to darker as it changes channels. I thought that auto dimming was turned n again, but it isn't.
I've tried fiddling with the settings, but nothing seems to cure this. Not sure if it's Sky causing it, rather than settings on the TV.
However - one thing is that FILM MODE was set to HIGH. I've tried setting it to off, but no matter what I reset it to, it stays as HIGH.
Am I missing something here, or is this a fault I should report ?
Have you returned it yet? We have the latest update ( Dec 2015 ) and it still freezes, restarts itself, loses channels and so on. Sony support is expecting owners to fix this mess. We have done a factory reset as suggested. They seem to think we should accept this as normal and something all computers do! I looked after a network of 140 Pcs and did not restart as often!
Auto TV on = on? Maybe
Peter, can you give us any definative answer on when the next firmware update is due. The Sony info page changes a lot and the Feb EU/March UK update is specific to features, PIP etc, which to be honest is the least of most peoples issues on this forum.
Is there a bugfix release planned this side of Christmas or in January? Clarity would be great and might allow some people to make decisions on whether they want to keep the units or not.
Thanks
I'm not sure how it's supposed to be set up correctly, in the absence of a proper manual, but in the bravia sync settings I have everything on. This way when I press the sky button on the sky remote, the sky box, TV and soundbar switch on. It does take some time for audio to come from the soundbar as you've noticed.
I'd love to know how to power it down the same way, it all has to be done separately at the moment.
Here is my promised update since Dec 10th update AND a factory reset. Still fresh set up no apps installed other than supplied ones. Less than a day since factory reset.
1) using YouView search, via the remote and on screen keyboard, the response is so slow, laggy and erratic it took me 4 attempts to enter a 3 letter search string.
I'll add to the list as and when I discover more.
I am another one who can't use Amazon Prime UHD, comes up with licence_error and please contact Amazon Customer Services. Maybe sometime next week if it doesn't come back.
